First RGT workout ride
I have just done my first workout on RGT using magic roads. There are few questions I have
  1. Can you change the erg levels on the go like you can on a normal Systm workout?
  2. I asked for 20 real time bots but none appeared on the ride
  3. I was under the impression that the ride would loop if it came to an end before the workout ended but it didnt. I had a 50km ride loaded with a 2hour zone 2 workout and the ride ended at 1 hour and 42 minutes which was annoying.
  4. I dont seem to be able to pause a ride mid session is that normal
  5. you don’t seem to be able to schedule a workout ride. I used create event and tried to schedule it for a hour later but it wanted to start in about 4 minutes every time?
    Thanks
Is this the case - you have to match a workout with a route that will take longer than the workout?
Routes will only loop if they are a loop (start and finish same place). If it’s a point to point route it will end at the finish
Looking further I should have added another lap when I created the workout, that would have solved it I presume?
Good to hear there is a solution!
Yes, that’d do it. Either pick a route that is definitely long enough or a loop and enough loops.
