Messed up RGT installation, update now is persistent
Hi
I succeeded to mess up my RGT Installation
Remove / reinstall or repair does not work
“Update Now” shows every time i start the app from the start menu
I have created a shortcut to WahooRGT.exe in …\Wahoo Fitness\Wahoo RGT as a work around this works fine
Not sure if I get notifications when I do it like this?
Thanks /Peter
If you uninstall AND remove the shortcuts, then reinstall, you should be fine ?
You’re getting it right that the shortcut should point to the new version of the RGT while it seems to be using the old location so far
