Cant get RGT to work. Windows 11 laptop, brand new top spec gaming machine. It (appears to) install ok, opens when i run it but as soon as i am past the login screen I get a flashing red symbol bottom right. I’m guessing it is some sort of connectivety issue. If i try to ‘Just Ride’ i can select a course, it appears to download but then gets stuck on connecting. Tried reinstalling RGT, downloaded latest version this morning.
I’ve checked the connection and it is fine. Wifi close to the router and wired achieve steady 50Mbps down / 15Mbps up.
I’ve tried disabling Windows firewall. No other AV software installed.
Any ideas…#pullinghairout (if i had any…)
Replying to my own message…I got it sorted.
I remembered some quirk setting on our router that we needed to change to get the smart TV to work with Netflix. Tried the same change for the laptop with RGT and it now works perfectly.
Happy days
Good news! The flashing symbol indicates a local connection issue, not server side.
Glad you got it sorted! Hope you enjoy!
