This little thing connects via a USB cable to your PC and lets you control your workout from the palm of your hand.
If anyone wants to try this at home, the CircuitPython code is here.
The next project I am looking at will do away with the keyboard entirely, instead there will just be a clickable spinning knob with RGB LED lighting that can sit on your stem or headset top-cap - click to switch between ERG & level mode, rotate to increase/decrease difficulty, double-click to pause/play. It will be interesting to see if that works as a user interface…
Excellent work. I’d still sweat all over it. I had thought to attach sensors to the two brakes. Currently learning Python though in order to connect an ANT+ stick to Home Assistant on a Pi so it’ll have to wait.
There are some 3D-printed cases available and the keypad itself is a single piece of silicone, so in theory this could be made sweatproof quite easily…
