Use the Discourse App to access The SUForum on your mobile device!
Did you know that Discourse (the maker of the forum software that we use) has an app for your mobile device? It’s called Discourse Hub and you can find it in your preferred app store.
Apple App Store
Google Play Store
Once you have the Discourse Hub app installed, it’s quite simple to add the SUForum to the app. This will give you full forum functionality from your mobile device.
Here are the steps required to add the SUForum to Discourse Hub…
Step 1: Click on the button that says “Add your first site”
Step 2: In the box at the top of the screen type in the SUForum address - forum.thesufferfest.com
Step 3: Once the SUForum is found select the “connect” button
Step 4: Select allow to any prompts that ask permission to allow the app to access the site
Step 5: Select the “Sign Up” or “Log In” option
Step 6: Select the authorize button to finish the sign in process
If you have any trouble with these steps shoot me a direct message and I’ll help however I can!
Excellent! Thank you, Sir Cody.
