I’ve just swapped out the Shimano 11 speed cassette that comes with the kickr core v2 for a Sram PG1231 XPLR Cassette HG 11-44T so I can put my gravel bike on the trainer rather than the road bike I was previously using.
Once I begin to pedal by hand to test the set up I encounter resistance, the pedalling feels stiff and I can hear rubbing or friction. Has anyone else experienced this or know what’s happening and how to solve it? When the thru axle isn’t tightened the issues starts to go away but as soon as I tighten it (so the bike doesn’t fall off) the issue occurs.
I’m using the 142 on the non drive side and adapter C on drive side.
Any help would be much appreciated.
Thanks
Did the stiffness start right after the cassette swap? I’d double-check that the cassette is seated properly and the spacers are right for the SRAM cassette on that freehub — a missing or wrong spacer can cause binding. Also make sure the thru axle isn’t over-tightened, since that can put extra side load on things.
I solved it.
The issue first occurred whilst using the black adaptors that come with Kickr core v2 so I swapped them out for the silver ones you can buy separately to see if that made a difference. It did not. So I thought I’d try the black ones again and everything is fine. The only difference I noticed (considering they are exactly the same bar the colour and material) is the black non drive side adaptor manages to really fit in snug and isn’t loose where as the silver one is. Very odd but all good and thanks for your reply.
