Wahoo from Samsung S9 to iPhone17
I have Wahoo app on Samsung S9 and used it for 6 months now, want to move it to new iPhone, iPhone does not accept my password
The apps should use the same login and pw on every platform, so be sure to verify that you are using the same account name/email.
I am using the same login and password on both the S9 and the iPhone
Double check to ensure you’re using the correct login info. If you are still having an issue then contact Wahoo support.
https://support.wahoofitness.com/hc/en-us
Maybe Sir @Rupert or Dame @Helga can help you in the meantime.
Problem solved!
I am new to Wahoo and I did not know the app well, I simply forgot to logout on my Samsung S9, I did so now and then I could login on my iPhone. Maybe the app could be improved by clearly saying’ You are already logged in’ instead of suggesting that the email/password combination is wrong. Oh btw, How can I close this issue?
Thanks for the support
Marius
Glad you got it working! :+1:
I’ve logged into SYSTM on multiple devices and assumed the same with the Wahoo App.
Glad you’re now logged in!
