Speedplay Power (Wahoo Powerlink) - 100% L after coasting
Hi,
Getting back into cyling after supporting the two daughters Travel ball softball. Decided to give Speedplay Power try.
My power meetet is constantly reporting 100% L after coasting. It doesn’t matter I start with the Left or Right pedal. The only time it will report 100% right is if I un-clip the left pedal.
Wahoo Fitness Support has been working with me on this. I just installed the replacement unit and it is behaving the same as the original unit:
Hardware:
  • Speedplay Power
  • Garmin 850 or Wahoo Fitness app
  • Specialized S-Works crank
Below snapshots of a easy short ride which clearly shows the issue.
The 100% does not affect the power data/stastics. It does have a small affect on L/R balance statistics.
Has anyone seen something similar?
This could easily be addressed with a simple update by “ignoring” L/R balance output for the 1st crank revolution after coasting.
Appreciate any input/comment.
Jerome
