Hi everyone
I don’t understand why I set 7 power zones and then exit the app. Every time I reopen the app the zones become 6
SYSTM aka Wahoo X doesn’t allow customizing power zones atm.
You won’t be alone here but I think there’s a LOT of confusion out there concerning this forum, which is essentially for people who use SYSTM or Wahoo X (which used to also include RGT a simulator similar to indieVelo or Zwift) and those like yourself who I think are referring either to either the Wahoo App/Wahoo Fitness App (WA) or the Wahoo ELEMNT Companion App (CA).
I assume you’re referring to one of those. That said, I am unable to replicate what you’re saying myself. When I change the zones from 6 to 7 (in both the WA or CA), save my change, force quit the app, reopen and the zones are set as 7
Edit: and welcome to the forums @oberti, I’m sure you’ll find the help you need here as a lot of folks here do use those apps too.
Thanks for your help…yes I’m referring to CA but when I change the power zone number I don’t see any Save button or other option to save the change.
Anywa thanks for your help
Yep. In the WA there is, but not in the CA. For me, it just keeps the change I make after force closing and reopening.
Are you force closing the CA?
Yes but the zone return to 6
2 more things to try. One, are you using the most current version? Two, if you are you might wanna try deleting the app, restarting your phone ane reinstalling. That will cause you to lose your previously paired sensors though and maybe even your settings so if you don’t want to do that, then you might want to contact The Company directly. I’ve always found Wahoo’s CS to be exceptional.
https://support.wahoofitness.com/hc/en-us/requests/new?ticket_form_id=120257
Nothing…I’ll try to contact wahoo factory.
Thanks again
Good luck. Lemmeno how you make out if you remember to check back in here ![]()
Out of curiosity what are the zones you’re using and for what purpose?
I ask bc, I started out w standard friel zones, then decided I needed more zones, but eventually decided I really wanted fewer
I got a response from the wahoo team…
The Wahoo team knows the problem and they are working to solve it
Excellent! Soooo glad you reached out and thanks for the update!
this problem still not fix
On what app? On both the WA and the CA for me, I can change from 6-7 or 7-6, tap save and it sticks so after I force close the app and re-open it, my changes are kept.
What firmware version of each app are you using and is it a problem on both?
Companion App 1.77.2.2
This is interesting. On my android phone it’s also version 1.77.2.2, but it is not presently available on the Google Play Store. I wonder what’s going on there! I think I’ll put in a support ticket, just to find out. It was originally installed from Google Play, so I how this is just a glitch!
Edit: the above is the version that the Wahoo support site lists as current, updated a bit over 3 months ago
I’ve seen on the interwebs that there’s an issue atm with Wahoo and the Google Play store. Not sure if it’s limited to wahoo or if others are also having problems.
CA(elemnt) Android is 1.77.2.2 , I had posted a ticket 9 month ago .
Wahoo:
Thank you for letting us know about your experience. This is an issue we are aware of and we have opened an internal ticket with our development team to investigate and resolve the problem.
Since we have an open ticket with our development team, all customer service tickets related to the issue (including this one) will be marked as “On-Hold” and merged with the developer ticket to be monitored internally. This process allows us to send automatic notifications to you via email when changes are complete. Full release notes are posted on https://support.wahoofitness.com
Be sure to keep your app and device up-to-date to receive the fix, when available.
Google store is not available for wahoo right now
