Error message
Hi All.
New to this. When I try to run a session (through calendar, select training mofule, press Start) i get the following message:-
"The address wasn’t understood
Firefox doesn’t know how to open this address, because one of the following protocols (sufferfest) isn’t associated with any program or is not allowed in this context.
You might need to install other software to open this address."
Please help!!
Hi Shaun and welcome. Have you installed the Sufferfest app for your device (installer here Get Started with The Sufferfest) and done a reboot since? If you can’t launch from the web calendar then opening up the Sufferfest app and launching from there should always work. If you need help getting going then contact the minions and they’ll sort things out for you Need help with The Sufferfest App? Contact the minions for fast support!
Many thanks James
I am now up and running, and look forward to beasting myself in Sufferlandria! (and looking at the weather forecast I won’t be heading out doors for a while!)
Thanks again,
Shaun.
