From the Coaches: What is Fatigue?
Different types of fatigue and how to combat them
We are all familiar with the feelings of fatigue in whatever form they strike: be it by the end of one of the giant mash ups when we just want to curl up on the floor and cry; or once we have attempted that ninth hammer in Nine Hammers and our legs are screaming at us to let them stop. But there are many different types of fatigue and understanding what they are can help us combat them and reduce the onset or impact of these various fatigues.
Hydrogen ions (recovery)
The first one that we are going to talk about is one you would’ve likely heard referred to as lactic acid buildup. However, this is quite a misleading title as lactate is not something that directly fatigues us and, in fact, is something that our body uses as fuel during efforts and can be converted into pyruvate which is then used to make ATP (adenosine triphosphate), which we know to be the energy source of all bodily functions. The real culprit of fatigue here is something that comes with that lactate production: hydrogen ions. Increased levels of hydrogen ions (H+) create a more acidic environment within the muscles. This, in turn, results in something called ATP hydrolysis, which is the process of ATP being split into ADP (adenosine diphosphate) and inorganic phosphate (Pi). This happens because the enzyme that causes ATP hydrolysis (ATPases) does not work as well in an acidic environment. This not only impacts on our ability to utilise the energy available in the ATP we create from substrate utilisation, but also our capacity to produce muscle contractions.
We can reduce the negative effect of hydrogen ions by improving our buffering capacity. This can be done by using supplements, such as beta-alanine or bicarbonate of soda, or we can improve our ability to utilise fats as fuel at higher intensity, which reduces the production of lactate and hydrogen ions that come with it due to carbohydrate metabolism. When hydrogen ion levels do get so high that they cause fatigue, the best thing to do is to reduce the intensity, which then enables you to clear the hydrogen ions faster than you are producing them.
Substrate availability (carbs)
Another form of fatigue comes from substrate availability. Simply put, this means having the fuel available to conduct the work. Higher intensity work requires carbohydrates in order to complete it, but our carbohydrate stores are not indefinite. With our muscles and liver saturated in carbohydrates (muscle glycogen when it’s in the muscles), we have perhaps enough carbohydrates to fuel 90 minutes of high intensity exercise. This is why consuming carbohydrates is vital to allow for prolonged high intensity work. When we do not consume enough carbohydrates, we are unable to complete exercise at higher intensities, as even with a lot of fuel in even a very learn person’s fat stores, fat metabolism requires more oxygen to break down than carbohydrates so can’t be done when oxygen demands are very high such as high intensity exercise. This means the only way that we can continue to exercise is to reduce the intensity dramatically. This is likely the feeling you will have encountered if you’ve ever suffered the dreaded bonk. Your legs go heavy and there is no intensity that you can produce other than one that is essentially just turning the legs very, very easily.
Fortunately, this one is probably the easiest form of fatigue to combat. We simply must ensure that A) we’ve consumed sufficient carbohydrates in both the day leading up to, and on the morning of, exercise, and B) for exercise sessions longer than 90 minutes that we consume carbohydrates during the session as well. The amount of carbohydrates that you can consume depends on your ability to process them. Traditionally, we’ve been told that 60 g an hour was the maximum we could consume. This then increased to 90 g an hour when a mix of fructose and glucose was consumed. Nowadays it is considered that up to 120 g of carbohydrates can be consumed per hour when mixing different carb sources - as long as our gut has been trained to deal with the high carbohydrate load. It’s important to consume the carbohydrates before we feel that we need them. Once we hit the point of fatigue due to lack of fuel, it’s too late as the time required to get the carbohydrates into the working muscles means we’ll have to spend a period of time working at a very low intensity in order to recover. For those just starting out with carbohydrate fuelling, it’s best to start with maybe 40-60 g an hour. After that, you can train with increasingly higher carbohydrate loads to improve your body’s tolerance to carbs and ability to utilise them.
Inorganic phosphate (recovery)
Another cause of fatigue (and usually the one that leads to the pain we feel in our legs) is something called inorganic phosphate. This is produced in especially large quantities when we suddenly go from perhaps a very low intensity to a very high intensity. For example, during sprints or micro intervals. Inorganic phosphate is produced during ATP hydrolysis and also when using the phosphocreatine pathway to produce energy, which occurs during very high intensity or the initial uptake of high power. So, when you go from 40 W to 400 W in your micro intervals, the phosphocreatine pathway is how we initially uptake that power. Or, even when starting an endurance ride, the initial energy system working will be the phosphocreatine one, with the aerobic system is kicking in shortly afterwards. This also explains why we feel more fatigue when we have a lot of changes in pace, such as in a criterium or after conducting micro intervals. The production of inorganic phosphate leads to a reduced cross bridge capacity within the muscles, which is how we produce our power by contracting and releasing the cross bridges (see sliding filament theory). It also reduces the potential power from each cross bridge, resulting in a double whammy of power reduction.
We can reduce the impact of inorganic phosphate by pedalling at an easy intensity after the repeated bouts of exercise that produce it or immediately after a large sprint. Studies have found that stopping peddling completely keeps the inorganic phosphate levels high and reduces our capacity to perform sprints again. So, in races, it is a good idea to reduce the amount of surges that we do as that will reduce the inorganic phosphate production. In training, after doing a high intensity sprint, it is important to remain pedalling at a low intensity rather than stopping pedalling entirely.
Heat fatigue (a good fan and cooling of the hypothalamus)
Heat fatigue affects us in several ways. The main one we’re going to talk about is heat production itself and how that affects both the muscles’ ability to contract and also our ability to utilise fuel sources. When we work in hot environments, we become less able to use fats as fuel and more reliant on carbohydrates, which itself causes greater hydrogen ion production and therefore quicker onset of fatigue. The big issue with heat is when it affects our core temperature as, when that increases, a lot of enzymes in the body are unable to function properly and we therefore lose certain functions such as the ability to break down fuel.
The other way in which heat causes eventual fatigue is by dehydration. When we become dehydrated, we experience a reduction in our salt balance as salt is required to move water from within the body to outside the body to allow evaporation to cool us down: this is essentially sweating. With salt levels reduced (often called electrolytes), we lose some of our signalling capacity which is how our muscles contract and release. You may feel particularly bad cramps after being dehydrated, for example when your calf muscles tense up without any conscious intention to do so. This happens due to electrical signals not been passed properly to the muscles, and all muscle cross bridges by nature are contracted, hence why rigor mortis occurs in bodies. We actually release the muscle cross bridges with energy so dehydration, often accentuated by heat, can cause cramping by failure to release – or relax – the muscles.
There are various ways to reduce the impact of heat fatigue. One method is heat acclimatisation which essentially involves training in a hot environment more regularly and increasing our ability to sweat in order to reduce body temperature. Additionally, it has been found that making sure the hypothalamus section of the brain is cool has a significant effect on body temperature. An easy way of doing this is by putting an ice pack on the back of your neck. Ensuring that you have a good quality fan in your turbo room, as well as maybe a dehumidifier, will also go quite a long way to reducing the impact of heat on your performance. Another very simple way to combat dehydration is not only to consume enough water but also to ensure that enough salt is being consumed. This is hard to get exactly right unless you have your sweat tested for the amount of salt per millilitre and then also have your sweat rate tested. However, the amount of salt required is often higher than you would expect when exercising hard in the heat.
Hopefully you found this piece interesting. Let us know in the comments any stories of how fatigue has really hit you and how are you combatted it.
This article was fascinating and erases all vestigial guilt about my dietary habits - now I can refer to my constant snacking on sweets as “gut training”. Time for another couple Stroopwaffles along with my morning pot of coffee…
If you eat those during training you can blag that as legitimate training :stuck_out_tongue:
A good succinct article. The issues re inorganic phosphate and the hypothalamus were new to me. I will not be carbo loading on sweets though :joy:
Inorganic phosphate was a fairly new one to me this year! It’s amazing how scientific knowledge develops, going from Lactic Acid, to Hydrogen Ions, to Inorganic Phosphate being found to be the cause of this particular form of fatigue. The Hypothalamus one presents an interesting point as you could fit implants into a helmet in the right place that could help cooling that region. I remember a few years back a few conspiracy theorists suggested a certain TdF rider was using a helmet implant to make him immune to pain :sweat_smile: carbo loading on sweets during a ride isn’t necessarily a bad thing, just got to make sure you brush your teeth well after!
I love and appreciate this post.
While fatigue might not be the correct term, technically speaking, I think you can still get what I am trying to ask here:
Would it be possible to go into why after some rides, I feel a deep sense of drowsiness about three hours later and want to sleep, but my muscles don’t really feel any pain or fatigue? Whereas others I don’t feel tired really at all but my muscles “hurt”? Some I don’t until that evening, around the time I usually would, but with a lot more pronounced sense of sleepiness than usual. All this on the same more or less the sleep patterns/schedule.
Superb post. Thanks @Coach.Andy.T.
That used to happen to me when I first started “seriously” riding about 30 years ago. I attributed it to glycogen depravation.
The muscle pain is likely from changes of pace in an effort, like Violator! That efforts requires a lot of changes in pace which really drives the inorganic phosphate production and the sore legs. Whereas a long slow ride will use a lot of energy over the course of the ride, but not cause the same kind of muscle fatigue, and is likely to result in drowsiness
What would you consider The Downward Spiral? Did it yesterday and didn’t really have any pain from muscle fatigue, but about ten hours after finishing, I wanted to pass out and had an almost subtle ringing sensation over my entire body. Hard to explain.
I’d be really interested to know how much bicarb of soda I should take and when is the best time to take it…
This is a great post @Coach.Andy.T, thank you.
A related question (and apologies if I’ve missed the answer already) - are there specific recovery protocols for the different types of fatigue you list? My specific situation, I tend to find the leg pain (damn that inorganic phosphate, apparently) is the one that always gets me. Sure, there are plenty of times that I’ve felt drained, or bonked, or have just generally been barely hanging on, but come the 9th Hammer or the 2min 14VG interval, or plenty of other moments when I do have fatigue in the body, it’s that leg pain that forces the stop.
Should I be thinking about recovery in a particular way? (I’m letting you believe that at the moment I think about recovery at all here…:slight_smile: )
L
Did you refuel and rehydrate well after it?
It’s a difficult one as it varies on body weight, tolerance, and also how you’ve loaded. I tried it once before a race without trialling it. Needless to say I had a :poop: race in more than one way so always best to start low and build. It’s not essential, and is certainly a marginal gain, but something that can be trialled out
Unfortunately the recovery for H+ and Pi is rest or recovery, so spinning between the efforts. The hammers for example try and offer just enough recovery for the hammers but harder as you go on. The more you train your aerobic engine the better you will become at clearing those metabolites. So short term active recovery, long term improving aerobic fitness will help
I drink two liters of water a day basically. Normal girl up afterwards.
Given that depending on your sweat rate you may lose between 500ml and over 1.5l of sweat during a heavy intensity turbo session, it may be worth drinking more based on the sort and amount of riding that you do on a day. Making sure you have enough salts as well
Yeah, I’ve since been adding salt to my water since, after listening to an episode of Knowledge.
Wow, just read this for some reason – did not catch that autocorrect, huh? No idea what I was trying to say there… :joy:
