Hi there,
is it possible to visualize the remaining distance?
i went to map, distance, but cant find.
thanks
your wish is wahoo’s command. Literally. You can add the data field by selecting Map, then choosing Distance Remaining (route).
You can then view it from the Map page while on a selected route when you click the “…” menu on the unit, then Route Info:
Thanks Glenn
On mine it showed under ‘workout data’ the maps…with your hint I was able to find
Thanks again
