I boyght my wahoo Kickr in 2017 and it has been very reliable, never any issues. Had it out on the porch through summer, now I have moved it inside, there is no power, no lights. Any ideas?
Apologies if you’ve tried any of this already, but these are the steps I would take:
- check another device works in same plug socket, if not, then try another known working socket
- check kettle lead works with another device, if fails then try another lead
- check if power brick has green led lit when plugged in (assuming that model has one), maybe that is dead and needs replacing
I reckon it is indeed dead, there is no light on the power brick so I’ll try to replace it. Thanks
Hopefully just that that’s dead and replacing fixes it for you ![]()
They have replacements on the wahoofitness.com store
