Have you seen the new adaptive training of trainnerroad? Do you think it would be possible to have it also in Sufferlandria?
Very interesting and would definitely vote for this.
Not that much the TrainNow function but more than anything (1) the Plan Builder function they have and (2) the ability to adapt a training plan based on your performance in previous workouts.
That must be the future of training or the present !!!
@JohnK It adapts the training plan and what workout you do next, not the specific workout youâre doing in real time.
Looks interesting, yeah. But interesting doesnât cut it - for me. Wake me up when they pull in âevery-day dataâ like steps, 24/7 hr, etc to make an informed decision.
For whom might be interested, Ray Maker posted an overview.
On another note, I sincerely believe (not know!) that every fitness company who offers some kind of training plans is at least looking into this whole âmachine learningâ thing.
I do wonder if this might be something Suf are about to also announce. It has been a common request in the past to have alternative workouts to the ones in a plan, I wonder whether an adaptive plan, with some user choice, could be on the horizon?
On the Trainerroad podcast they said there will be a one or two question survey at the end of each workout, which will give them your RPE for the session.
@JohnK TrainerRoad is also asking you how the session felt at the end to add a a subjective piece. So if you hit all the targets and said it was easy, I assume it will ramp up the intensity on the next workouts. TR did say for now they only increase the intensity score of the next workout selected. They arenât increasing your FTP settings until you do another ramp test (for now). So if you were to repeat the same workout even after saying it was easy itâd still be at the same intensity, though TR would suggest a harder workout.
And thatâs part of another another big difference between SUF and TR. TR will have a base workout and then multiple versions of the same one with variable numbers of intervals, like imagine Revolver +1, +2, +3, -1, -2, -3, etc. The Shovel +5 (âŚ). Hard to see how SUF could do that with their video workouts. No Vid might be possible though.
Honestly with 4DP I feel like TSF is close to what TR is going to offer. TR is identifying 6 or 7 power levels and suggesting workouts based on your strengths and weaknesses (sound familiar?). I think if TSF could automatically detect 4DP increases based on HR and power data similar to how Zwift does it thatâd be good. Especially if they could allow us to import and analyze external workouts. I could see AC and NM being pretty easy to analyze actually because 1 min and 5 second max pushes arenât too uncommon when riding outside, at least for me. For example if my NM is 1000W and I have a 5 second effort of 1050W from an outside ride, SUF should be able to recognize that increase my NM. I think automatic FTP and MAP adjustments might be harder, but they seem to be doing based on power data and HR in the Half Monty. I wonder if similar principles could be applied to other rides.
Iâve been tempted to try TR a few times but really it just seems kind of boring. Their initial base build phase is nothing but Sweet Spot/Tempo rides for like 2 months without ever really pushing above threshold. I canât speak to how effective that is but itâs just so bland. And donât get me wrong. I can do 5 hour endurance rides and be perfectly happy. But I love the variety you get from day 1 with SUF.
Itâs a good point. I think as you said (1) heart rate but also (2) I think you can correlate workout difficulty (seems TR developed a pretty sophisticated way of doing this based on how they impact different energy systems) to how likely someone is to complete it; specially based on previous completes / missed and your 4DP profile which measures exactly that.
Another way is to ask once you complete the workout how you felt and how âflat outâ you were to prevent excessive fatigue build.
It seem they clearly found a way.
Sorry for the last post, I answered from the phone and didnât see the other posts
I did try TR twice (devoting quite a few months) and ad two main problems: (1) it is incredible dull indeed, even if you put your own media on the background, and probably more importantly (2) as Dylan Johnson points out, the training plans have an incredible amount of intensity which always led to me burning out after 1 / 1.5 months (and Iâve done a lot of intense plans in SUF and others).
Machine learning sounds like overkill here, more of a buzzword than anything else. (I say this as a software engineer who has taken a ML class, but who doesnât work as a specialist in ML.)
However, I think there are simple heuristic-based improvements that could be very useful.
Here are some things the system already knows:
- Your heart rate and its relation to the targets.
- Whether you are successfully completing workouts at 100%.
- Your training load.
- Your age, which could be relevant to recovery needs.
Some additional info it could get easily gather:
- Ask you to rate how the workout felt on a scale, immediately at the end of a workout.
- As how fatigued you were on the day. I think this would also be best asked at the end, because I often canât tell until the warmup is done.
If youâre consistently below the HR targets and you say workouts are easy, it could dial up the targets gradually. If youâre not able to complete workouts, it could dial down targets until you can. The four targets could even be adjusted separately, depending on the focus of the workouts and how successfully you did each type.
I would envision getting a notification upon completing a workout that this is going to happen for the next workout, and having an option to decline it. Also, the notification could say that itâs time to re-test. Perhaps the threshold for a re-test could be a bit bigger, and/or depend on the length of time since the previous test.
To add to your point, as someone who knows a bit about Machine Learning⌠for the purposes under discussion here, it really is just a refined way of doing statistical analysis.
The problem for me is that even with the known data, there is too much missing to build a model for ML.
There is too much missing to build a USEFUL model for ML. There are plenty of people out there building models for the sake of saying they have MLâŚ
A few things âŚ
(1) Predicting FTP: If I recall what was said during the TR announcement podcast, the ML-based FTP adjustments wonât happen until youâve completed their ramp test (they added âprogression levelsâ to help change the recommended workouts for you) at ~4 to 6 week training blocks in their plans. So no big difference in this regard from their current system, and not different from doing a Half Monty six weeks into your 12 week program. Also, this seems weaker than Xertâs algorithmic approach that updates your fitness signature after every workout, meaning your Xert-modelled FTP can change daily, in theory.
(2) Automatically updating your 4DP profile based upon bests from SUF workout history (badass power records) would be a bad idea as Full Frontal measures your power dimensions in relation to one another during the same test, in a set sequence, following a specific set of recovery periods, etc. To cherry-pick from your best power numbers without this context for your 4DP is just asking for trouble. I think the introduction of Half Monty (based on some modelling of The Sufferfestâs huge database of Full Frontal results) was a good move, providing way better bang for the buck than ML.
(3) âFTP is deadâ: While machine learning seems to be a big piece of their approach, it seems to me that after years of investment in development and delaying sharing the value of their work with their users, theyâll end up in a similar place to The Sufferfest by creating a unique power profile that goes beyond just FTP for users to customize their workouts with, except ironically with even more (not necessarily better) power profile dimensions (5-6 âprogression levelsâ).
There are plenty of bells and whistles and tech nerdery to get excited about in TRâs announcements for sure, but IMHO, the real value proposition for users doesnât seem to have tipped the scale in TRâs favour ⌠at all. Iâm still pretty damn impressed by The Sufferfest, 4DP, FF and HM, and future opportunities to dial in my training while keeping me engaged through the process.
Thank you for making that explicit. Foolish me, I just assumed that when one said model it would automatically be associated with âusefulâ. Nonetheless, you are correct.
Hahaha, I wasnât intending a rebuke of any sort! Iâm glad a fellow nerd agrees with me.
For the non-nerds out there, there is a famous adage âAll models are wrong, some models are useful.â All models are wrong - Wikipedia
Are we being a bit too fanatic here?
I love SUF as well but I think there are things to be learned from TRs new approach and I think it has little to do with FTP / 4DP and more with how plans evolve based on performance.
I donât think we know enough to say their model is wrong or mot useful to be honest.
I remember I have requested this to SUF every 6 months for the past 4 years now.
I think TR heard what customers have been asking for years now.
SUF has the 4dp nailed for a while now, and they could take HUGE advantage if they want it to.
Lets hope they have been working on it, and not make it as a reaction to the competition.
ML is the future of training. Thatâs for sure
Machine Learning means learning based on results. On the basis of what result would you base the learning?
For me, the result that matters is that of races. Even if youâre going to include A & B races itâs still only a few things to learn from. I suspect weâre dealing with a buzz phrase or the machines will learn from something that doesnât really matter.
Similarly âadaptive trainingâ means adapting to something, but what⌠the Sufferfest already adapts training sessions to a rider profile that is updated each Full & half Monty. I wonder what else they plan to adapt to & Iâm not going to listen to a ridiculously long podcast to find out.
On how well you performed on all the previous workouts you did. Valid right?
Again, letâs mot be fans for the sake of Bein fans and at least learn from this.
