Disappointment to find out that the Kickr V5 won't be getting Virtual Shifting
According to https://support.wahoofitness.com/hc/en-us/articles/16865097915666-Zwift-virtual-shifting-with-Wahoo-smart-trainers :
“We have reviewed the hardware and firmware capabilities of KICKR v5 (2020) and preceding KICKR versions. Unfortunately, these older models are unable to support the required protocols for Zwift Virtual Shifting and will not be receiving a future update for this functionality.”
Here’s the lesson: don’t buy their premium products, because an older and cheaper one will be more future-proof. What a slap in the face.
Absolutely this. I’m going to run my v5 into the ground then look at a competitor after that. Wahoo’s just been a long list of disappointments for me. Flaky HR straps, a flaky watch, now this :roll_eyes:
Yeah, unfortunately, I feel the same way.
My Kickr still works fine and I hope it will work for many years. I’m also glad to see that older devices get updates, like the Kickr Core, but it feels like a betrayal to know that they wouldn’t put in the resources for this update on the Kickr V5.
Although many people didn’t care, I felt disappointed to see RGT go in favour of Zwift. I thought they would develop it, no matter how slow.
@CYCLING-THERE Kickr v5 received direct connect which likely took up extra memory leaving none left for the click feature. I don’t think the Core has direct connect so there probably was memory to use for the click feature.
Whatever the reason may be, when you buy their premium there is an expectation to be a frontrunner for future updates. Plus, when they announced the virtual shifting compatibility, several YouTubers mentioned that Wahoo “said” that it would come to previous versions of the Kickr, but that it would take time.
That’s why it feels such a letdown.
Here’s something to keep in mind: I bought a Garmin 830 DATS before the 840 was released. I got a couple of updates and then crickets. There will be NO further updates. None. If it becomes vulnerable, you are told to turn it off and buy a new 840 or 1050. At least Wahoo hasn’t done this with any device that will support the requested update.
I think the devs really thought that they could bring the feature to KICKR v5 and they really hit a wall, probably due to some design decision made years ago.
It is sad, but they did try. On the other hand, this doesn’t prevent you from using your KICKR like you have been using it until now, it still works with Zwift etc.
I have a V6 and was curious about Zwift cog 2 & click. I imagine there’s not much use outside of Zwift, aka Systm doesn’t work with it or am I wrong?
You are not wrong.
That’s a bummer. Hope Wahoo adds the support for the gadgets like Play, Cog and Click in Systm so users can use them in both platforms. That would be freaking awesome :slight_smile:
It may be coming. The best part is the Cog will work with ERG mode.
How?
I’m speaking about Virtual Shifting in SYSTM, not on the K5. There’s a hard stop on that, unless you want to lose DirCon and Wi-Fi
I see.
Does the V5 have Wi-Fi?
It has DirCon. That apparently leaves too little space for Virtual Shifting.
Agree with disappointed comments above. At the time, I purchased the flagship smart trainer from wahoo. Now no support for firmware upgrades that already accommodates ERG mode? I’ll ride this trainer into the ground and shop your competitors Wahoo.
Bullshit. V2, V3, V4, V5, V6 and Core use same processor by Nordic. V2&V3 use only one mark on flywheel, V4/5/6 core - 4. There are no big difference between V4/5/6 & core. In v6 wahoo added ESP32 wi-fi module, but main chip is the same as in V5.
I’ve found an app that works around this. I have the v5 and zwift ride. Was also super disappointed when I realized virtual shifting wasn’t available. I ran across the QZ app on YouTube and Reddit and gave it try. I have zero affiliation with the app and will admit it’s not super intuitive to use but after trial and error and reaching out to the developer I was able to get the settings right and it works. I have full use of the zwift ride controls and can virtual shift on zwift and zwift recognizes it and shows gear shifting in the game. The way it works is instead of using zwift companion you use the QZ app and it connects to zwift. I have an Apple TV running zwift, you first connect to the QZ app and then to zwift app on Apple TV. There’s actually a YouTube video showing the app working and the process to do it. Roberto Viola is the developer and I had multiple emails back and forth to get the settings right but I do have a fully functioning setup now. App is 5 or 6 dollars one time pay and obviously worth it. I use iOS but it’s also compatible with android although I can’t verify that.
App Store- QZ-qdomyos-zwift in App Store
