Kickr Bick Shift: Garmin settings "wheel size" and "gear ratio"
Hello,
I just did the setup of my Kickr Bick Shift and in my Garmin (FR955) the settings sensors>smart trainer> “wheel size”, “gear ratio” and “bike weight” should be set to what?
Also I see the Garmin watch only connect to the smart trainer through ANT, isn’t possible to force Bluetooth?
Thanks,
Any responses to this? I’m keen to hear as well.
Hey again, Craig, since the post is 7 months old, I’d guess the OP got the answer from Wahoo Support or just figured it out on their own.
Wahoo support rarely come in to the community forums so if you’ve got specific questions or issues about your setup it’s always best to contact Support directly. This way they can log the issue, as well as check their system to see if others have experienced something similar. You can put in a direct support request to wahoo here:
Edit: I’ll add that from your other post I thought you had the Kickr v6 and this older post was about the Kickr Bike Shift.
