Kickr Core compared to Assioma Duo Power
Okay, so we agree that the drivetrain power loss is somewhere in the 3-4% range and probably much closer to 4% with a typical road 2x gearing setup. So power measured at the pedals should be 3-4% higher than power measured by the trainer at the rear hub.
You say the Assiomas are listed as +/- 1% accurate when calibrated and the Kickr is +/- 2%. So unless at least 1 of these devices is incorrectly calibrated, or faulty, then I don’t see how it is possible to end up with power measured apparently 2% higher at the trainer. That would require at least one of these devices to be well out of its stated spec. If the Assiomas were reading -1% and the Kickr was reading +2%, then you would still see a 0-1% higher power reading at the pedals.
FWIW in my setup with a crank power meter and Elite Direto X (which has an optical power meter) I consistently see 4-5% higher power measured at the crank, which is exactly what I would expect, knowing that my drivetrain is not perfectly clean!
@KevinD Did you find a solution in the end?
Has it continued to consistently be out by same % even after spin downs etc.
Have you been using assioma Uno or Duo. Guess if your left leg was weaker the assioma uno’s would under read. Eg if left/right split was 45/55 (quite extreme but not impossible) the assioma uno would register 90% (2x45) of the actual power you put through both pedals together.
2% lower would fall within the combined range of stated accuracy of the two devices though, so it’s not the biggest problem in the world and if they track, then they’re both consistent, which is enough to work with when training.
That said, I have both a Core and Duos and find mine to be pretty much 1:1 if both calibrated.
Just to revisit the first point though, the Assioma Duo give a stated accuracy of +/- 1% and the Core +/- 2% which could combine for a 3% discrepancy in the worst case. Your 2%, so long as they consistently track, is basically “good enough”
I switched the Assioma Duos back onto my outdoor bike so haven’t compared them in a while. I think though the answer to my question is that it falls within the accuracy range for both the Assioma and Core. My left/right split is normally 49/51 so too close for that to be the issue I’d say
I have a substantial difference in watts of around 20-25, between what the Kickr Core calculates and the Assioma Uno pedals, both with calibration performed.
I view the Assioma uno on Garmin 1030 while the Kick Core on the phone app or on the tablet with Zwift. Can someone help me to fix this difference?
Several causes and the first is way oblivious: Your left leg is stronger than your right. In my case I ride 56/44 to 54/46 balance.
It seems a popular setup. I have Kickr Core and Assioma Duo.
I notice too that the Kickr gives slightly higher power readings than the Assiomas, by around 2-4W, so around 0.25-2%. I must admit it has never worried me but I have thought it was odd as it should be the other way round due to drive chain losses.
My assumption has been that the Kickr has been calibrated to give assumed pedal power, even though it reads at the rear hub, but maybe my drivechain losses are less than assumed.
Whereas the Assiomas read at the pedals so don’t need to make correction for this.
Mine experience so far quite the opposite. My Assioma Dua pedals are reading higher slightly higher power numbers (about 5W-8W higher) as compared to the Kickr v3 I have.
Something to think about is are the numbers within the tolerance specification of the devices? If they are, carry on. If they aren’t, may be calibration time.
