Maintenance Plan
Hi all,
One mainly for the admin / minions / minion admin.
I’m setting up my 2021 plans and think I’ve found something missing in the plans.
I’ve got 2 Mt SUF plans for 2021 and they are 1 month apart.
It would be great if there was a SUF plan for a recovery week / maintenance plan / taper week.
I wonder if it would be worth / possible for the SUF gurus to come up with short term interim plans for this sort of issue.
I’m sure I wouldn’t be the only one wanting this and think it would be a great plan for what to do ‘in between plan’.
Is this an idea or should I just go freestyle and design them myself?
Possibly not exactly what you’re looking for but the coaches do have plans for recovery plans…
Perfect…I must be finally thinking like a minion! Just need maintenance and taper plans :grinning:
I was thinking the maintenance plan could be in 2 week blocks so you could just keep redoing it as needed.
You could try the “All In” plans, as they’re based on maintaining fitness. I did one a few months ago and it had a nice mix of base work with some intensity. Could be a good option?
Hold tight a little bit longer as we are working on something which should be able to help you here.
In the meantime, check out the All in as @Alistair_Brown recommended or also the base training building block (find out more about building blocks here)
CHOOSE THE BASE BLOCK IF:
  1. You’re transitioning from the end of a race season or the completion of a goal event—such as your “Mt. Sufferlandria”— that you’ve been working towards for several months.
Hope this helps and we may have more for you soon… :wink:
