Systm crashing in OS26?
Anyone else having trouble with System on MacOS26? It’s stopped loading videos and regularly the app just go to a black screen.
Reinstalled, logged out/in, same problem.
On iOS 26 it is also very unstable. White screens and nothing happens.
As an update, so far I’ve sent Wahoo screenshots and videos, but the problem is unresolved.
Am I’m the only one where Systm stopped working on MacOS 26?
I get your frustration I’ve had similar problems on macOS where videos won’t load or the app goes black. Make sure both macOS and the app are updated, try clearing cache if possible, and check for any interfering apps or extensions. Sometimes completely removing the app along with its support files and reinstalling helps. Have you contacted their support yet? They might have a fix for macOS 26.
Thanks @zirken12 - how do I find the relevant support files? I’ve searched around hidden files but no luck. I’ve deleted the Wahoo cache files but no difference.
(And yes, I have a ticket open but so far just sending them more info, don’t think they’ve figured the problem out.
Hey! @Malte
If you’ve already cleared the Wahoo cache and checked hidden folders, the support files are usually stored in system-specific directories, depending on whether you’re on Windows or Mac. Sometimes they’re in:
  • Windows: C:\Users\[YourName]\AppData\Local\Wahoo Fitness\
  • Mac: ~/Library/Application Support/Wahoo Fitness/
Make sure hidden files and folders are visible.
If you still can’t find them, the best bet is to ask Wahoo support to point you directly to the file path—they can often guide you better than searching manually.
Hope that helps!
Has there been any resolution for this issue? I have been having issue with instability of the apps, both SYSTM and the Wahoo app, with iOS 26 for my iPad Pro. While I seem to solved the instability, it will connect now, however the resistance for the power setting is definitely not accurate. At 100 watts I am barely able to rotate the pedals. In the Wahoo app this is resolved by lowering the watts in ERG mode to 20 watts. In SYSTM it does the same.
Wahoo Support while very responsive have offered no help as yet. They indicated it was interference from another connection, but I have literally gone as far as turning everything electronic within range of bluetooth completely off and still have same results.
My trainer, KICKR v5, has been in the same place with exact same surroundings since purchase in June 2021 without issue till about 3 months ago this started.
Any possible solutions would be appreciated.
