Hi,
Recently I bought a Bolt v2 and the hour on device is 1 hour ahead of real time.
The activitie is with the right date time, but in the unit is showing 1 hour ahead.
Any glue how to fix that?
Hi,
Have you used it outside yet? My Garmin sometimes needs to be used with gps on to “find” the right time zone. Always happens with my Fenix if the battery dies while I’m traveling. Once I get home, after I recharge, i need to take it outside to find the satellites before it updates time zones
I found a way to manually adjust the time, I change it and works! Thanks guys
@Djalma_Junior how did you do? I have the same problem with my Roam unit and it’s quite silly and irking. no matter if I adjust time and/or timezone manually, it always get updated by its own with 1h ahead whenever I boot the device.
Thanks for sharing.
ok, way too long after struggling with this I found way to fix it.
With the unit off, change the configs on your phone as:
Hi, I’m having the same problem, but i can’t fix it in my phone (iPhone 15). I set “automatic off” and put my time zone (Santiago CL), still does not show the right time… Any other solutions?
