Completed the ramp, not good my fitness is going down.
Changed to level mode.
Now I use a Wattbike artom.
Found I couldn’t change gear.
This bike uses cr2023 coin cells in the changer.
All fixed now but need to repeat the test haha
Physical issues accompanied with technical issues does not make for a pleasant experience….not that FTP tests are meant to be pleasant! Bestvofnlucknin your next HM go!
Same thought as Sir Eric… technical issues plus fitness test equal the ultimate mental toughness challenge.
Hope the next time is smooth as silk!
One time I was riding on my dumb trainer and suddenly found I couldn’t shift. Couldn’t even pull the lever on my shifters!
I looked down and saw the cable had worn thru the cable housing tube!
Took my bike to the LBS to get some long-deserved maintenance. After that my bike shifted smooth like melted butter.
I believe that is called the “Quarter Monty”.
1/2 the results of the Half Monty, but twice the irritation.
A few years back I rode FM only for the results not to save as my old Mac didn’t have enough memory left. I even rode it again with the same problem before I figured out the issue.
That was definitely a Double Nil Monty with a Yak Milkshake on the side…
