Hi, I am a long time Bolt user. I got a slightly used ELEMNT Bolt v2 from a friend. I factory reset the device and updated to the latest firmware. Everything works perfectly, the rides are recorded and sync to Strava, but the device does not measure elevation. During the hilly rides the “grade” is always 0.0, and total ascend is 0 ft at the end. I cleaned the barometric sensor. Am I missing anything else or is the sensor broken?
Did you managed to solve the issue? I have same pb and couldn’t find any solution so far…
would be interesting in how you fixed it, in case you did.
How did you clean the barometric sensor? assuming it is located in one the two holes in the backside of the device, which one of the holes is it?
