Final Surge
Is there a way to export a training plan to final surge?
I’ve got my plan set up in the app but when I add the plan to final surge it doesn’t match up. It was completely different workouts for the same day.
Any ideas what I’m doing wrong?
Thanks!
The plans in the app have been modified over time and the plans on FS and TP will no longer line up. This allows SUF to tweak the workouts without having to worry about updating other platforms. What should happen though, and I’m not sure if this helps you or not, is that once you’ve done a workout in SUF it will upload the completed workout to FS or TP. So you can still track your activities in FS, you just won’t be able to use FS to look ahead. You can now view future workouts either in the app directly, or on the web from any device of your choosing.
Thanks for the reply! I only wanted to use final surge so that when I’m planning out a week, I can move workouts around by clicking and dragging them. I can do that in the sufferfest calendar when I’ll need to manually change the dates. It takes a little longer, but it’s no big deal. Cheers!
