I recently signed up for the 14 days trial and hopped on for the full frontal, but that didn’t work out at all because it was giving me half power readings.
I use a wahoo kickr core and assioma favero uno power pedals. The pedals are configured not to double the power in the assioma app. But when I turned on my bolt I could see that I was pedalling with 120 watt, but the sufferfest was only showing 60 watt. So I had to push way to hard to get to the required power.
Did anyone had a similar problem or has any idea where to look to fix this?
I think you’ll need to set them to double the power. Head units tend to be better at identifying a single sided power source so they automatically so the doubling. But a lot of apps need the power meter to deal with it. From memory Ant+ usually deals with it better but Bluetooth is where you get the issues as by default the pedals broadcast as two separate pedals.
Even on my Duos I have it set to merge into one Bluetooth channel.
^^ this ^^ and hopefully you have time to get a few workouts in and can iron out any of these things before a next 4Dp - good luck with the next test …
SUF instructions say not to set the doubling . If you’ve not seen these they’re here, maybe there’s some combo of settings that you’re missing. Email the minions if not, they’re sure to get you sorted.
I’ve had a similar problem with 4iiii one-sided PM on my SUF early days.
As I remember it was somehow concerned with a few devices battle for pairing with PM device.
After I ensured that only the tablet with SUF sees my PM then it appears that I should have had 2 options to connect PM in SUF: as PM and as left-only PM. Choosing the right one solved my problem.
