Inconsistent sensor connections
I really hope the team gets this and can address
Since the first version of Sufferfest stand-alone software, sensor connection has been unreliable and inconsistent. It is demonstrably an issue with the now SYSTM app, as Trainer Road has zero issues connecting.
First - why do we have to start a ride for the sensors to connect? Can the app be modified to connected sensors before the ride?
Secondly - can we have spin down for Wahoo Kickr and other devices in the app? I am using a PC to ride and have to connect with my phone to spin down which is a complicated symphony of enabling adn disabling bluetooth before and after spin down.
I missed 20 minutes of HR values on my ride today. very frustrating.
This is, I’m pretty sure, coming hopefully moderately imminently.
This may then be alleviated by the above issue of having the sensors connected in the app as a whole, not just the workout player
On my iPad and on my Mac (when I’ve used it), SYSTM remembers all my previous sensor connections and the ones in range just connect within a few seconds of starting the ride. All I do is check that everything is as I want it and close the window. I’m unclear what can be improved from that. Does your setup work differently?
(While my new KICKR doesn’t need spin downs, I totally support integrating that.)
I’ve run back to back workouts. I just have to wait a second or two–which is about how long it takes me to reset myself. But maybe my stuff just connects faster. If it were slow, it would be a pain.
I can concur with the OP on this one, it is one of my bugbears.
I rarely have to dump my connections, but sometimes if I want to run back-to-back sessions I have to close SYSTM and re-open it. It’s almost like it’s not properly releasing the devices, but the new player is a new session so it’s not still connected either…
I certainly hope so!
The problem is that the app is not consistent with its ability to connect, and that inconsistency is not part of my setup as another application that does the same thing (TrainerRoad) would always connect, consistently, even on technology 10 years ago.
I am using a PC and connecting via Bluetooth. Even though ANT+ work(s/ed) on TrainerRoad, it would not consistently connect in Sufferfest.
Sometimes all sensors connect immediately, sometimes they connect after a couple minutes. Sometimes, I need to start the ride, wait 5 minutes, then restart the entire application.
This is entirely software related and has plagued the software since its inception. I even stopped using SUF for a time because of it. I am hopeful that with the capital resources of Wahoo they can address this.
I’ve been lucky. But the user experience shouldn’t rely on luck. Hope the minions make this better.
Definitely agree that the Fulgaz method of connecting at startup is inconvenient for things like calendar changes, ride profile checks, or anything else where you’re not riding.
SYSTM has got me back into doing yoga daily, which has actually greatly improved my cycling performance and general quality of life due to pain issues, and it seems silly to force yoga users to deal with sensor connections. I do more short yoga sessions per day than I do cycling sessions, although cycling is my primary reason for being here, and my sensors connect within 15 seconds of hitting start for a ride unless my phone has grabbed one of the relevant BT connections and won’t relinquish it.
Yoga users would not have to deal with sensor connections. It would all be background.
Again, my only point is the inconsistency. It is not reliable. If it would reliably load before every ride, then it would not be an issue. They don’t have to change when sensors load, just make it more reliable.
