Lap swimming - laps are not counted
I have the Rival watch since 2 weeks. I want to use it for swimming (crawl). In the pool I want that the laps are counted, total time and time per lap. The problem is that neither the laps nor the meters (pool length 25 oder 50 m) are counted. Are these simple features not forseen or is the default setting simply wrong.
Hello,
This is usual failure of the watch OOTB. Get in touch with support you’ll get a replacement watch.
Thx for the info. What means OOTP?
Out Of The Box
Hi Pouta, support made a replacement and the new watch works fine - laps are counted correctly. Thanks for the hint.
My RIVAL worked fine for my first 2 lap swimming sessions, but then it stopped recording laps in the middle of the third. Is there any procedure to reset or unblock the accelerometer? The watch is already a replacement, so one of the latest batches I suppose.
You can try to shutdown the watch and restart it, or do a factory and hope for the best. If this does not work, then you’ll need a replacement
Thanks for the advice, I’ll try it.
Can I test the swimming sensor without a pool? Like by waving my arms around like a lunatic maybe?
As for the replacement, since watch was already replaced in April, I’m afraid to send it back to get one from the same batch.
I’ll get in touch with support if factory rest does not solve anything.
