What an I missing, I don’t see where to change the workout between level mode and erg. The only option I see now on Android is powered by 4dp.
2 weeks ago I could select level mode.
Violator recommends using level mode… But it’s not available to select
Once the workout is running, select the gear symbol (settings) and under sensor connections, there will be a little drop down under your connected trainer with the option to change fro Erg to lvl.
Sometimes it needs a couple of seconds once it’s connected to your trainer but is definitely still working:
Thanks Dame Lisa… I knew it was something simple
All good, glad it was helpful!
