Power drops
Frequent large power drops while in Zwift.
Apple TV gen 3, Wahoo Powerlink Pedals, Elemnt Roam, Kicker Snap
  1. Turn on Elemnt Roam
  2. Start spin down on kicker
  3. Calibrate pedals
  4. Start Zwift on Apple TV
  5. Initial power displayed is reasonable for my weight and perceived effort
  6. Ride a few miles, then displayed power drops dramatical, (not to zero)
Kickr Snap should be well warmed up before you do the spin down. 10 mins minimum. Also, you should make sure your tire is inflated to precisely the same psi prior to the warm up and that you tighten the knob thingy exactly the same number of turns. And this process should be followed each and every time
Also, do you have the latest firmware installed?
