Kicr v5 doesn’t show power/cadence on Zwift or Trainerday until ~1:30 into factory spindown warmup
Recently, after a hiatus from cycling due to my son being born, My Kickr v5 will connect to Zwift and Trainerday via bluetooth no problem, but 9/10 times there will be no cadence or power data until I start a Factory spindown and am about halfway through the 3 minute warmup. Then the resistance on the warmup will dump (also not sure if there should be this much resistance on the factory spindown warmup, feels like 350 watts) and whatever app i’m using will start to measure cadence and power. I am unable to complete a factory spindown at this point because my speed will never go above 19, despite full on sprinting and grunting.
At this point, whatever app I’m using is displaying something for power and cadence…and since I can’t do the factory spindown, I usually force close wahoo and then the app starts reading my suggested warmup power (this morning 78 watts), but at a resistance that feels to be many times more watts (78 watts felt like at least 500). Then I can do the automatic spindowns by getting up to speed and just stop the pedaling. But it takes several of these automatic spindowns before power feels realistic. At this point when power feels right if I transition back to factory spindown in the Wahoo app I can complete it.
I know that multiple apps shouldn’t be connected to the Kickr simultaneously, but through days of troubleshooting and experimentation, this is the only way I could get an indoor ride done. I definitely tried making sure the Kickr was only connected to Wahoo for factory spindown and then only connected to Zwift or Trainerday for the workout. All firmware/software etc is up to date. Picture of this morning’s workout in Trainerday attached. You can see throughout the warmup the power was reading exactly on target power, but this felt much higher than 78 watts. You can also see the 5 auto spindowns I did as the wattage drops. After the 5th, power seemed correct and measured much more realistically and erratically (at this point I was somewhat gassed from putting out what I assume was 300ish watts for seven minutes non consecutively)
I think the issue may be that you are trying to do a Factory Spindown on a unit that specifically is designed to NOT have you do a Factory Spindown.
My 2 cents:
  1. Make sure you have the latest firmware installed.
  2. Using the WA only, record a ride on your bike for about 10 minutes making sure to coast for a few seconds every couple of minutes and allowing the unit to internally perform it’s auto calibration.
  3. After that, go to Zwift and/or Trainerday and do what you would normally do but DO NOT perform another Factory Spindown.
If the above does not resolve your issues, then I would highly recommend contacting the support folks directly:
Edit: I should add that there is nothing wrong with having multiple apps connected to the Kickr and Kickr Climb. I do that all the time and usually with SYSTM on my MacBook Air and Zwift on Apple TV, also using the Zwift CA, while listening to music from my phone airplayed to bluetooth speakers or wireless earbuds. Oh, and I’ll also be running a Kickr Headwind, wearing a Trackr HRM, and, on occasion running an Ant+ cable to record my Garmin ant+ only cadence sensor.
I see your point about the Kickr v5 not needing factory spindown (allegedly), but that is the only way I can get power and cadence to read on Zwift or Trainerday. I should have mentioned I rode with no resistance or power/cadence readings for about ten minutes before trying the factory spindown this morning, just hoping it would start reading. I also let it spin down a dozen or so times. There’s something about the factory spindown that starts the resistance and readings in Zwift/Trainerday. I have replicated this workaround for four workouts. It just sucks because every workout is a zone 5 when I start out this way! :joy:
yeah, that shouldn’t be. Make sure you contact support then. They should be able to get you sorted. Don’t expect a response on the forums though. I know they lurk here and do chime in now and then, but the best place for service is direct.
I wonder if something is interfering with your signal. I’ve had this happen when I have opened another app that “grabs” and hangs onto the control even after closing it. Might be worth the old, toggle your BTLE off and on again and see what happens.
And, just to be clear, when you are running Zwift and Trainerday, which app are you giving trainer control too? And, I assume you’ve force closed (swiped up) the Wahoo App while you are in Zwift/Trainerday
Edit: oh and welcome to the forums and CONGRATS on being a parent!
Support ticket in. Thanks for the help.
One thing is that you gave to be on the LATEST firmware version on all of these. You can try the manual calibration on the V5. If that isn’t working through the Wahoo App, you need to contact support.
Coincidentally my Kickr V5 is suffering the exact same problem.
If it’s cold the unit will not transmit any power and cadence data, after about 2-3mins of warming the device up power and cadence suddenly start working.
I also thought it was related to the factory spindown, which I was having to perform before any training session for power to start working. However, I’ve noticed that it’s simply due to the device being “cold”.
Maybe the V5 have a genuine fault because I see more and more of these issues being reported, and the early V5s are now over 5 years old. I bought mine in Nov 2020, never had a problem with the unit until about a month ago.
I’ve been having almost this exact problem for about 6 weeks, except it’s got worse over that time. It no longer seems to broadcast at all. I’ve done all the things - all software/firmware up to date, multiple power cycles, many attempts at factory spindown (only managed to complete it once and that was AFTER a ride). I’d hoped that would resolve things by resetting the brake, but the next day it was back to playing up.
It connects, there is just no power broadcast. I can see rpm on zwift in the pairing screen, I can see speed on my garmin, and one of those (I can’t remember which) in the wahoo app. But no power.
Issues with the factory spindown were the same as described - felt too hard for the warm up, and couldn’t get the speed up no matter what. I’d either give up or get going til it timed out. For a few weeks this would get it going, but no longer does. Plus it added 10-15 minutes of messing around before every ride.
I’ve tried having everything else out of the room (headphones, phone, speaker) or unplugged (Kickr Climb) - it makes no difference (never has but it’s always suggested).
It’s also an early V5 and has been flawless up til the last few weeks.
Wondering if either @Matthew_Conway or @GlacialCurve managed to get this resolved. Is it even worth raising a ticket or is it time to replace it?
My unit still has the same issue. However I use it in “dumb mode”.
I connect the kickr to the wahoo app and start a workout, then select “resistance” mode and set resistance to about 20%. I connect my 4iiii crank power meter to MyWhoosh/Zwift and off I go, after about 5-10 mins the kickr starts broadcasting power & cadence data (can see on the wahoo app), but it’s unreliable.
I raised a ticket with wahoo but they aren’t interested because it “works” after being warmed up (although it doesn’t because it keeps cutting out).
I tried that and even that stopped working on the 2nd ride.
I ended up getting my spare unit back off a friend (a 2018 Core that crapped out back in the days of lock down - was able to get the new trainer weeks before I could get new bearings). Thankfully that is running nicely.
Plan is to make time one day and open up the v5 to clean the sensor. Maybe even have a crack at replacing it if that doesn’t fix it.
Good luck…. I don’t think it’s a replacement sensor in my 22case, the power measurement works, it just isn’t being transmitted until the unit is warm. I’m assuming it’s a fault with the PCB. I’m a SW engineer and used a BLE sniffer, there was simply no power/cadence data being transmitted from the unit.
I was lucky, I guess. I made a ticket with Wahoo and they sent an RMA slip for the broken one and shipped another refurbished (my first was a refurb purchased direct from Wahoo) one almost immediately.
Im having the same problems as well. Kickr v5 worked perfectly up until 2 months ago. Now its not sending power and cadence. Speed is always there but not accurate. I can get it working after a proper warmup for 20-60 minutes. I have been troubleshooting for long sessions trying to figure out what made it work this time. Until i realized it was just the warming up. Now its just not working since i dont have the patience to hope its going work sometime soon.
I reached out to support who gave me a 12-step troubleshooting scheme (all about bluetooth interference) and a diagnostic workout routine using wahoo app and target power. I went through with all of it and the workout failed 4 times due to trainer putting out way to much resistance and still showing no reasonable data. But the fifth time it worked (after warmup) and wahoo support pretty much said “well there you go, no problems here. Enjoy your day BYE”.
+1 on this issue. Moved indoors this weekend to begin winter training on my KICKR v5 after a surprisingly warm October. I only use the SYSTM app for indoor training with the KICKR, TRACKR, CADENCE, & HEADWND. My KICKR v5 connects to my phone but doesn’t measure or control power, speed, or cadence. I tried all the suggestions in the article at: KICKR is connected, but no speed, cadence, or power data - firmware is all up-to-date, paused all apps but the Wahoo app. I also attempted a factory spindown, but the measured speed won’t get above about 16 mph. As I pedal faster, the speed drops.
I’ve read here and elsewhere about cleaning sensors. If that’s something available for KICKR v5, can someone point me to a resource? I’m not shy about disassembling electronics for this kind of “tier 2” maintenance if I have some idea of what I’m getting into and steps to follow.
I also put in a support ticket. I’ll share what I hear back here. It’s been reliable for me since I got it for pandemic fitness in Oct 2020; 5 years later (and knees that are 5 years older) riding is my primary fitness for fitting into my clothes…
:crossed_fingers:t2:
I went through the Support system and chatted with Mackenzie. Like others, I went through the firmware update and reboot options but still had no power or cadence info, despite being connected via bluetooth to Zwift and then to the Wahoo app on my phone. Mackenzie was fantastic and after I sent the photo evidence of a “field retire” (cut the power cord near the housing with the serial number showing) and the receipt from Competitive Cyclist from 2020, I have received a brand new KickR V6 that seems to work just fine. 10/10 for Wahoo Service Support!
