Anyone else noticed the “power profile used” section usually within the calendar of a completed ride isn’t showing for “on location” rides?
At the point when i probably need to retest but putting off FF and i can’t recall what numbers i had manually set at.
Hi @adcords would you have used the same numbers for it as you had say on other rides ? Or did you use others ? Is the On Location rides the only rides you’ve done on SYSTM ?
I had increased the % from my usual power profile in systm for this particular ride. I also had done half as easy before hand and that shows the power profile in the calendar.
Bit odd it’s not showing, thought it might be a bug with the new systm
Might be one to send to the minions
