Question: Are POWRLINK ZERO Pedals compatible with pedal extenders?
I see the standard (Q) for POWRLINK ZERO Pedals is 55mm. I currently ride my non-power meter Speedplays with a pedal extender that takes them out to 75mm.
Although the Wahoo spec sheet site says spindles are available to 65mm, I think that refers to non-power meter systems(?). The navigation makes it hard to be sure.
Also, it says that spindles >55 are not sold onsite; you are referred to a retailer. I called a couple and neither seemed interested in investigating whether they could find one that is different from the standrd 55mm.
