Updates to element
Hi !
When I connect my phone ( android) to my Element Bolt 157C to load my workout, I always get a message :
Current version: WB-16244
Your verssion : WB-16333
DO you wan to update ? I say yes …and then get the same message again with same version numbers.
This has now been going on for a month or longer ( I finally started checking the version numbers! ) Clearly not updating. NOT a network problem ,
Any advice ? Does it matter ?
I had a similar issue and found out it was a lack of disk space that prevented the update.
If you check the system settings and see how much you have. Personally I ended up connecting to a laptop and removing a load of maps to clear some space so I could update.
Thank you ! I just deleted a pile of maps of places I never expect to cycle and problem solved! (( I did not know all those maps were even there…!)
