Wahoo Kicker Slipping Handlebars
I’ve owned the Kicker for a few years and the handlebar has been slipping down every few weeks and it takes a huge effort to clamp it back together.
I’ve tried the official recommendation of clamping the metal together overnight without a handlebar inserted with no luck.
Lately I wonder if anyone used a spacer like this to keep it physically from slipping? Any other input or tricks to fix this issue permanently will be appreciated. It’s a bit disappointing for a $3000 equipment to have such basic issues…
I assume by this statement that you have already reached out to Wahoo support about this issue?
Yes, the recommendation was to pull out the handlebar and clamp the quick release tight overnight.
Last time I checked the fourms it appears to be a common issue.
Ok. Sounds like you’ve done about all you can far from coming up with a solution on your own. Maybe reach back out to Wahoo support and see if they have come up with anything else.
