Kickr bike - slipping handlebar / seatpost
Hi,
Got a new Kickr Bike v2 today. First small tests and the handlebar and seatpost slips. I have to tighten it very hard to make it stay. My wife will also use it but is not that strong. For a bike at that price this should not be an issue at all. I see many others has the same problem.
On a bike where you bump up and down during many rides outside this is not a problem. Inside it is for a bike standig still???
Guess this should be written to support but I needed to get out some air …
Edit (19.11.2024 ): Thanks for good answers! I will surely look into the 3D printing, my brother in law just bought a 3D printer :smiley: The seatpost is not slipping much but the handlebar are a problem. I added carbon paste and it still slips but not more than a 1cm/hour(!).
It’s perfectly fine to vent here but do be sure to reach out to support. They don’t often check in on the forums.
I had exactly the same problem with the bars my v1 bike. I got a temporary quick release fix from the local bike shop while I talked to support who sent out a new official one straight away.
I’ve always had great support so talk to them and they will sort you out.
I just got my new Wahoo Bike Shift, I’m 6’4”, 185 lbs. My seat post slips down. I’ve tightened it and used a torque wrench to tighten to 10, 11, and 12 Nm, and yet it still slips down as much as 7cm.
Support sent another post but it looks the same, so wondering if anyone has a solution that worked.
Carbon paste and 3d printing a wee wedge to sit in the gap between the d shape seatpost and the rounded seat tube is the only thing that worked for me in the end.
Together with a far superious QR seatpost clamp.
However, it does now mean its not so easy to adjust frequently so my daughter can ride the bike too…
Thank you #DameLisa I’ll try that
Where did you find the wedge for printing DameLisa?
The carbon paste worked for me. And I’m about 200 lb. If you’re in need of a quick solution, maybe a hose clamp acting as a stop would work?
Thats a good hack actually
A friend printed it for me
I found two 3D print companies one local here in Richmond VA, 3D Central, and online PCBWay.com which was less expensive. Getting on material local and two online. Ordering was easy for both. Used file found through Redit
Kickr Bike (Shift) Seatpost Spacer by derpuma - Thingiverse
Wahoo does have a solution a round shaped seat post with a ruler printed on the post. Work through support. You will need a new clamp which they provide. The clamp previously used with the original D shaped post seems to be out of round when tightened down on the original D shaped seat post. New post holds as expected.
