Full Frontal, Half Monty for the constrained portion, Violator (you’re just supposed to give it the beans 64 times), I like to use it for Cash Register during the sprints, same for SUF Idol, the full-on sprints of The Shovel and Tool Shed, any of the no-vid sprint sessions and Standing Starts.
Oh, much more than I’d imagined.
Now I’m secretly hoping you’ll test it out as I’ve been thinking about getting the app for a while now ![]()
I’ve sent the Dev a message. He says it’ll work on the Wahoo App, I’m just waiting for him to clarify that it will work in SYSTM as the two are, at least for now, different. I don’t mind spending the $7 CAD to test it.
Excellent, looking forward to your updates!
Well, he says it’ll work so I’ve dropped the 7 pebbles and I’m off to fiddle. Stay tuned.
First update, Sir Denis @hobbyhoarder. Tl;dr: It works.
There’s a fair bit of fiddling though and it’s not super intuitive either. Seems I had to switch the sides of the controllers to get the right side to change to a harder gear and the left side to change to an easier one. Also, with the Climb engaged, each gear shift (up or down) corresponded to a rising/lowering of the Climb. I don’t want it to do that. I’m not sure if that’s cuz I had turned ERG off and had SYSTM set in Level mode 0-1 but will need to explore more (when I’m not in my pyjamas).
So, the short answer is it definitely works in SYSTM. The longer answer is that it’ll take me some more fiddling and reading to find the right settings for gearing (you can use the “experimental” Zwift Gear ratio or the QZ default. Using the Zwift one left me with only 12 gears (it skipped up and down by 2 with each shift), whereas there is 24 that are available on Zwift itself. Using the QZ ratio just had me perplexed.
Thanks for the update! Happy to hear you got it working, even if not fully yet. Maybe the app works by changing the grade for the trainer? That would explain why your Climb would also go up or down.
I’ll be getting the app soon as well. I don’t have the Climb to test it on, but I’d say contacting the developer again would be the best option. He seems to respond very quickly and is probably eager to fix any bugs.
Not all heroes wear capes
That’s Captain Canada, Cap’n Sir. Captain Canuck has no need of a shield. GAWD!!!
Fwiw, it looks like Captain America has changed a little recently too ![]()
Well yeah - fewer guns… ![]()
Ha. We are kind of stabby though ![]()
