My first Wahoo Roam stopped updating in December of 2023. I continued for months trying to update it. I tried 6 or 7 different networks, factory resets, and unpairing/re-pairing the device with the Elemnt app, nothing worked.
I had to field retire my device in late June or early July and get a new one which also will not update. Again I have tried 10 different WiFi networks, including two different phone hotspots, factory resets, and unpairing/re-pairing with the Elemnt Companion app.
What can I do to get this fixed so I can update my device?
I have tried different networks, I have tried different phone hotspots, I have manually selcted the “Update” option from within the Roam itself; all for nothing.
I cannot express how incredibly frustrating this is. Between lack of updating ability, and the fact that my Rival continually loses data while I am riding, I am beyond angry with my Wahoo experience.
Something needs to be done about this, because if I cannot trust the devices and the tech behind them to be reliable so I can get the most out of my workouts, I have to go to a different product. I cannot continue to make it halfway through a ride to have the Rival or Roam lose then “recover” data. Countless times I have lost data an hour or so into a ride, and then again two minutes from home, turning what should be a 60+ mile ride into a 20 mile ride, losing all of my data.
Please fix this. This is absurd that I cannot trust my devices which I paid so much money for. Please fix this.
Yeah, I have reached out to support on several occasions, and they have not been actual help in resolving the problem. Support is what got me the warrantied Roam after I field retired my first one, but everything they recommended was something I tried, and it went nowhere. If I am going to have the same issues with my new device, which is looking likely, I’m getting a Garmin. I can’t do this with an untrustworthy device.
Currently I’m on FW WC24-15475 trying to update to FW WC50-17026.
You’ve got the ROAM v2 right? When I look at the firmware page, I don’t even see WC24-15475.
I see WC19-15475 from November 2022. I assume you’ve tried a full factory reset? Also, are you sure you’ve got enough room on the unit? Sometimes people have nearly ALL the world maps installed and rarely, if ever need them. Might be worth pairing that down to what you actually need. For me it’s just Canada and a couple of US states.
Edit: Oh, and fwiw, I only update from the ROAM v2 itself. I’ve had mixed results when using the Companion App.
Yeah, I’ve tried full factory reset three times. I do have enough space on the unit, I didn’t download any maps, I’ve got a little over 1 GB of space right now.
I can’t even get the update on the Roam itself to update properly. It says it’s checking updates, but never actually installs anything, and I retain the same FW.
I hear your frustration. I’ve been using a ROAM v2 since they came out and it’s been pretty solid. There is a little trick that worked for me when I got stuck in an update loop some time ago.
I’ll see if I can find it? For it to work you’ll need to be able to connect to a computer and actually see the internal files. Are you able to do that?
Edit: you’re doing this at your own risk (I don’t work for wahoo) as I got the advice from Reddit and it worked for me some time ago. 2 methods:
1: Delete folder ‘system_update_elemnt’ on pc and reboot device and update again.
2: check the sdcard\system_update_elemnt folder and delete all files in it, reboot and update again.
I have a bolt 2 that will not update. I had to take it to an at&t store and the were able to get it to update l i also tried several different networks. Nothing worked you may try that.
I’m an customer. They connected to their wifi. And was very helpful. You may try your carrier. Still can’t figure out why I can’t get it to update. Hope it helps keep me informed
Make sure you find a tech savvy representative. She said she had to go in the app. I’ve had 3 updates since but not worth going back for another update yet.
It was a last resort for me. Support didn’t help. Tried everything they suggested. I know more people have to have this issue. They need to do something to fix the problem.
I also had trouble updating, and the quoted solution fixed it for me, and my ROAM 1 is always up to date (although ELEMNT app constantly prompts me to update when ROAM is connected even though I have the latest firmware).
As imilicivic has stated, you have to change the security protocol on your WiFi router to lowly old WPA (or dual WPA/WPA2 if you have that option). You will then have no issues for your Roam 2 / Bolt 2 etc updating. Also needs 2.4 Ghz band but if you have the dual band set to 2.4 ghz / 5 Ghz you will be fine.
Why Wahoo would be using a chip that’s limited to WPA (“Wi-Fi Protected Access”) only I have no idea. The WPA security protocol was introduced in 2003 so more than 20 yr old now. WPA2 was introduced not long after but is significantly more secure and since then WPA3 has introduced stronger encryptions. Basically, WPA is no longer considered secure with TKIP vulnerabilities that allow WPA to be exploited with modern tools and techniques and in fact many modern devices will not work with WPA. Except your Wahoo of course!
Since I wasn’t prepared to have my home network open with WPA, I set up a separate WiFi network on my mesh router just for my Wahoo Roam 2 connect to and set the security protocol to WPA/WPA2 and the firmware updates work fine. I don’t use that network for anything else. I
I’ve left my main home network on WPA2 – I’d prefer to switch it to the WPA3 option but I have a few devices that won’t work with WPA3 either.
