I got an Element Roam for Christmas and when on the app, connected to the head unit, it says an update is available (see image). When I press this, nothing happens. I’ve tried it not plugged in, charging, at 50% charge and at full charge. I have then tried to go into settings via the device itself to ‘check for updates’. It says ‘waiting’ but does nothing beyond that.
It’s not very well explained, but usually if you leave it connected for a while it downloads, and then installs/restarts automatically. It’s erratic though - maybe depending on WiFi connection. Has been like that for me from the beginning.
I appear to have found a workaround for having a 5Ghz wifi at home… I put Personal Hotspot on my phone with Maximise Compatibility on which puts your hotspot at 2.4GHz. Connect the app to the hotspot to run the update.
