OK. Sometimes, if FTP is a weakness, you need to improve your MAP first if the ratio between them is too low. I think you’ll be OK with your FTP building block plan.
Couch to Crusher depends on how active you are on the bike right now. Have you recently started cycling (again), or have you been riding regularly and you just want bigger numbers?
Plans are a bit fiddly, IMO, because you generally need a goal or some target. “I want to get better” is a great layperson’s statement but doesn’t mean much in a practical sense.
Do you have a local ride or hill you’d like to complete? Maybe a metric century?
It really helps to have a SMART objective.
Edit: I’m just an amateur at this, too, so take this advice as it’s intended
@Fatboi Perhaps a coach would think otherwise but personally I wouldn’t worry about a building block as it sounds like you are just looking to ride and gradually progress. So all purpose road should fit well with your goal of being a better cyclist. Note that the plans are going to be adjusted for your specific metrics so you will still get plenty of sessions that focus on FTP improvement. Also check out the mental toughness series, yoga and perhaps strength.
Remember that the journey that you are on is not about being the best - it is about being your best so don’t worry about the actual numbers, just the direction and velocity of those numbers!
Hello. I also did the program from couch…and I was very happy with my progress specially in 2020…i want to start again the same program, but I can not figure out with SYSTM which one is…can you help me?
Thanks
@Dan_Mihaila I also completed Couch to Crusher previously but unfortunately it appears to have been removed in Systm. The fitness kickstarter that @JSampson mentions is a 6 week plan - C2C was a 10 week plan. If you still have the old app installed on a device you can add it to your calendar from there.
