So for Suffs and Evil Laughs, I decided to do Zwift’s Baseline Camp. 3 workouts and 3 tests to give you a report on your strengths and weaknesses (and get some in game rewards that are pretty meaningless to me).
It comprises 3 areas, Sprinting (10-20 secs), Attacking (up to a minute) and Endurance (10 mins +) . Sorta like a 3DP version of 4DP but instead of 1 test, it’s 3. Somewhere between Half Monty and Full-Frontal.
After each test, provided you’ve subscribed to the emails, you’ll get your test results and, once you’ve done all 3, you’ll get a report outlining your Strength and your Limiter.
Not surprised by the results at all. Sprinting is my strength, Endurance is my limiter. I don’t really see that changing and I was happy to challenge myself in a much less daunting way than Full Frontal, and to an extent, HM too.
No rider type result (just like HM) but it was a fun little exercise and Zwift has made some significant improvements in making their workouts a bit more engaging than the last time I’d done them. Eg. Useful, well timed text prompts, a little bit of humour (some almost SUF like) and helpful information about what and why you’re doing what you’re doing.
Imho though, NOBODY comes close to The Sufferfest for really engaging and motivating me to push myself during indoor cycling workouts. On Zwift when doing structured workouts, you’re still riding in a world where your efforts can be a complete mismatch with your environment. Eg. while the gradient might be pointing straight up 10, 11 12% or more, you could be spinning at 85-90 rpm for 10 mins at a recovery pace that you’d never be able to manage on a climb irl. I think that Zwift could change that if they dedicated resources to designing more workouts that match routes or designing routes that matched workouts.
Now, to be fair to Zwift, their new hill, The Grade, does also function as an FTP test so doing that in non-ERG mode does actually have your efforts matching your environment (it’s the segment they used for the Endurance Test portion of their Baseline Camp). Beat your time up there and you’ll get a new FTP result. That is actually pretty cool! The only thing is, (edit 2: unless you change your trainer intensity settings) you will be limited by your gearing. If you’ve only got a 39/25 ring/cog combo, you’re gonna be grinding your way up The Grade since it’s a 3.5 km segment averaging 8.6% with much of it at 9-10%. If you’ve got the gears, or better yet, virtual gears, you’ll be able to manage a higher cadence (I averaged 87 rpm).
Edit: linking the other thread on the same topic:
