Clear Tickr X offline memory
I picked up a used Tickr X and it has a bunch of old offline sessions recorded on it.
How do I clear them? I’ve tried resetting by flipping the battery.
I just want to say congratulations for having a still working TICKR X, that was probably one of the best devices Wahoo has made.
Seems solid if a little clunky, so I will use it for my indoor trainer. The strap also seems more robust than others, will more diligent keeping it clean so it doesn’t die from corrosion.
My previous Suunto monitor came back to life with a new strap and battery, that can be for outdoor activities.
Try it. You should be able to use it with a regular strap even though the TICKR strap looks different.
I do like the old TICKR strap as well.
Oh this may solve your initial question:
  1. Take the battery out.
  2. Put it back in upside down.
  3. Wait 3 seconds or so.
  4. Take the battery out and reinstall it correctly.
That’s the factory reset on most Wahoo sensors.
Have you tried syncing it directly with the Wahoo Fitness app? Usually, once the device successfully uploads those stored sessions to the app, the internal memory should clear itself automatically.
I’m not sure I want some stranger’s exercise data mixed in with my own. Would you?
Maybe I’ll have set it up a separate device/account on an old device to do this but it just seems weird there is no option to fully clear out the device.
