Data not showing on laptop when using Kickr and Systm
While using my Kickr and the Systm app on my laptop, I am not getting any readouts on power, cadence or mileage. There is no control from the Kickr. I am connected to bluetooth.
Sounds like a connection issue, trying turning it all off and back on again, make sure SYSTM is the only thing connected to your KICKR, and if none of that works, reach out to our support team https://support.wahoofitness.com/hc/en-us
Sometimes (okay, many times) when I start a workout, none of the green icons show up for my Kickr. If I either disconnect and reconnect, or unplug it and plug it back in, or remove it and re-add it, then it shows up a few seconds later with all the green icons and my power, and cadence, etc.
Hopefully that’s all you need to do.
The green icons show. When I start to pedal that data doesn’t show on the screen, not calculating the numbers. My Kicker gives no resistance or changes in power.
That seems like something is off with your trainer, reach out to our support team and they can help troubleshoot https://support.wahoofitness.com/hc/en-us
