Headwind and Garmin Chest Strap
I have a Headwind I usually use with SystmX. I’m also doing some racing on Zwift and having issues with controlling the speed of the Headwind from my Garmin Heart Rate Strap. It’s paired fine but I can’t adjust the Max/Min Heart Rates…using iPhone. The min HR is 115 which is too high for the fan to start working.
Has anyone else had issues doing this and solved it?
First thing is that you need to have WA connected to the Headwind to access the settings.
Also, have you done the recent firmware update that enabled adaptive cooling (HR and power at the same time for fan control?)
The app (I assume WA) is connected to the Headwind, firmware updated when I got it in January - it’s not showing as requiring update and I have adaptive cooling available.
Ok just checked mine and I can change it.
The Headwind must be connected to the app and on or you can’t activate the settings menu.
The heart rate strap must be active and connected to the Headwind (I.e. you’re wearing it).
Click the like I in a circle to the right of heart rate and the menu to change it appears.
Yup, I get that. But when I then try to use the arrows to change the settings nothing happens.
Other possibly dumb question: ios or Android?
iOS, not a dumb question at all.
@Softlips I tested it and saw the same thing. Then I selected forget device and re-paired and now it is working fine. Try that and let us know if it works.
Legend! That’s sorted it, thank you!
