Wahoo Headwind HR Connection
Hi all
Are you able to assist please?
I’ve just bought the Wahoo Headwind.
It’s working well connected to manual etc.
However, although it connects to my heart rate, it will not adjust as my heart rate increases (please see photos).
I have tried various heart rate zones.
I currently have Kickr Core, Garmin chest heart rate strap and Wahoo Climber connected.
Any advice gratefully received.
Many thanks
Peter
Firstly, your thr value and zones look wrong, way too low. Your threshold heart rate would be based on a fitness test, but you can set it to something like the average heart rate for what you’d be able to sustain your best effort over a 5k run or 30 mins on the bike. Then auto calculate button will properly populate the zone numbers.
Then you also have min fan speed set to 211 bpm, which is extremely high. These two numbers should be more like top of zone 1 and top of zone 4, which would mean the fan kicks in when you transition from zone 1 to 2, and it will be max when you transition to zone 5.
More info about THR here
Thanks Owen for your prompt response.
I’ll reset as per your comments, and hopefully this will work.
Kind regards
Peter
If you’re not sure about the numbers, you can set a default THR based on:
defaultTHR = 208 - (0.7 x AGE) * 0.88
Many thanks Owen.
@Waxi My Z2 HR tops out in the 130s. I have my fan set to come on at 105bpm and then goes to max at around 140bpm.
I have found that if you don’t start cooling early you can get too hot once you are through the warm-up. Sometimes I can be too cool early in the workout with those settings and may have a shirt on during that time but things are optimal once I get into the main workout.
Experiment and figure out what works best for you.
Thank you both.
All working perfectly now.
Many thanks for your helpful advice!
Great! Enjoy :slight_smile:
