I have problems with gearing/chain skipping on kickr core with 142mm thru axle.
The bike is a 12 speed Trek Madone 2023 ( Madone SLR 7 Gen 7 - Trek Bikes (NO) ) with a 142x12 thru axle.
The trainer is the OG Kickr Core.
I have the thru axle kit. With the 142mm installed on the non drive side with the arrow pointing inwards/to the right.
When installed, the 12 speed Shimano cassette outer lock ring aligns with the freehub lock nut (names from https://support.wahoofitness.com/hc/en-us/articles/4407141205522-Bicycle-Frame-Compatibility-CORE ). The end of the drive side spin cap sticks out about 8mm from the cassette.
On the Bontrager Aeolus wheel, the distance the end adapter sticks out from the cassette is 5mm.
Does anybody have any ideas I should try out or see what I am doing wrong that makes the gears misaligned?
-J
Do you have the “updated” thru axle kit referenced in that support article?
Yes, the pieces I have correspond to the updated kit in the article.
I tried to use the XDR part, which was 3mm shorter, but when I did that the freehub was loose (could move from left to right)
is there also that 1.8mm spacer behind the cassette? And, I’m sure you’ve already done this but just to be 100% clear, it is a 12 speed cassette you installed on the CORE right, not the 11 speed it came with?
12 speed casette on both the wheel and the trainer.
I don’t see any spacer when I take off the cassette.
K. Sorry, then I’m out of suggestions. Though, that said, have you contacted support yet?
https://support.wahoofitness.com/hc/en-us/requests/new
Hi, is it skipping on all cogs and when in little and big ring? Is it ok in the gear that you indexed it in?
I have founds one gear where it doesnt skip (big ring front, 3rd smallest back). Works for erg mode, not so good for Zwift
Thanks Glen!
John_B1
November 6, 2026, 11:18am
9
Glad you can at least use ERG, but that is confusing. Sounds like everything is like for like between bike wheel and turbo.
Any chance the derailleur or hanger got bent? Does it still work properly with your wheel in off the turbo?
