KICKR Resistance- Turn off
Good morning. I was wondering if there is a way to turn off all Kickr resistance? When I put my bike on the on the Kickr, I have to adjust my rear derailer, but having the resistance on makes it extremely difficult.
If there’s no power then there’s no resistance being applied. BUT there’s always inertial forces due to the flywheel (plus some general friction), and as that’s a physical element you can’t get around that.
My 2 cents are to set the Kickr to ERG mode at the lowest possible wattage. That should make hand spinning your cranks to adjust the derailleur easy as peas.
Thank you. It sure makes it difficult to dial in and fine tune.
I am going to try this. I wish there was a way to unhook the flywheel just to adjust.
Perfect. Thank you…Exactly what I was looking for.
No problem. I found this thread searching for the same info. Seems like a mechanical disconnect would be super easy to implement and 100% should be a standard feature.
