Gear indexing
Is there a way to drastically reduce the brake pressure so I can index the gears easier when on my Kickr Core? There is a fair bit of difference between my rear wheel and on the Kickr. Just want to make it easier to spin the crank while adjusting.1
Good question. I’d be curious to know too. I just get down on the ground and use what little upper body strength I have, lol.
I have always wondered if there’s a way to remove resistance completely like you would on a repair stand.
Edit: googled it. Just get the flywheel spinning then make your adjustments. Pretty straightforward.
Will give that a shot, thanks.
