Kickr Rollr cadence problem
Has anyone else been having problems with the Rollr cadence displaying very low when on Zwift? It never shows more than 70rpm on screen. It makes my Zwift guy appear to always be standing up and of course produces bad cadence data at the end. Things like an added cadence sensor or taking the cadence from my pedals do fix this but I like using this via my Apple TV and there just aren’t enough bluetooth connections available for all of this. Yes there are work arounds but I’d prefer to not have to use them and the Rollrs do the job properly. Thanks.
Well ROLLR doesn’t estimate cadence so it’s gotta be coming from your pedals. Assume you have the PM bonded to ROLLR in the Wahoo App?
Yeah I read it doesn’t do cadence after posting. I just thought it was supposed to do cadence after that update because it’s a selectable cadence source when pairing with Zwift, and spits out numbers from somewhere. PM (Look pedals) is bonded but I need to look at the app again and see if everything looks right in there after all. Thanks for the idea!
OK I don’t Zwift but in WA and SYSTM I think I’m using ROLLR as the cadence source and it’s just re-broadcasting cadence along with power from my bonded PM.
Maybe make sure everything is good with your pedals, check the batteries, etc
