Tagging @Rupert to look at this.
Interesting. Updated thanks.
If you shared to Strava please can you let me know what the name appeared as there too?
I reported this a long time ago @Rupert The name was the same on Strava as well.
Sorry I missed your note reporting this @jmckenzieKOS
Name should be correct on Strava now too
Thanks. I had reported it when it showed up in the app. Was kinda strange.
No, I think not. It’s a play on a wine-tasting description. Works just fine with “accent”, imho.
I knew this was the case but it really didn’t stand out until today. The rides seem to do a pretty fair job on flats and climbs balancing the watts to the incline for a speed calculation. I may be giving them way to much credit but it seems like it anyway. However, they don’t have a clue on descents.
I did Tour Down Under 2 this evening. There is a section where the descent is 4%, so they have you slow your cadence and watts way down (I was in ERG mode). So for some reason they also slow your speed way down. At 190# (90 Kg) on a 4% grade downhill, there is no way I slow down at all. Even if I stop pedaling, I will pick up speed. The advantage of being on the heavier side.
Just my 2 cents.
AC Progression 3
Two minutes left on recovery between blocks but text says 20 seconds to go (which alarmed me greatly at first glance!).
Both progressions have been updated thanks for flagging @Harpoon
AC Progression 3 text is now at 20seconds to go sorry for the scare!
MAP Progression 5 is 3 sets of 14 - I admit that is still a little scary!
I did Adventure For All this evening (very inspiring!) and noticed the description has it down as 50% FTP and below, but it definitely goes up into Z2 for a fair chunk and even Z3 for a bit.
Thanks I’ll get it updated!
Doing High Time this morning, I noticed a HR level change that makes no sense.
The very first two HR levels were Level 1.
Then the power steps up a notch, and we go to HR Level 2
The power then steps up another notch, and we go back to HR Level 1.
That makes no sense.
Your all misconscrewed, if the spellin and gramer is’nt correctt yore not suferingg enouff
In The Rookie, the bus driver during the rest after the first interval doesn’t have a capital letter on his name.
Duration is missing for one of the March challenge rides on mobile web page…
…unless the ride is 2023 mins long…
Also it does not show up in the schedule when you insert as a plan. Had to add it from the library manually.
I’m betting that what happened for you, is that since you added the plan today, the first ride in that plan wasnt added (since the first ride in the plan was on Tuesday, March 5th.
Given that these challenges are intended to cover the entire month, maybe The Company could insert ALL the rides for the month to the last day or the last week of the month, and instruct users to drag and drop them to the days that they’d like to complete them. Kind of a workaround to being able to choose the days yourself (which would be a lovely feature
Which is pretty much what I end up doing.
