Nit-Picks and Typos
The tiniest UI nitpick, but if you could make the upcoming phase indicator in the graph the same colour as the phase timer then it would help easy comprehension (instead of me just figuring it out 8 months later), like a shade of blue that works with the remaining power graph, for example.
Mental Training: 16. Regular Monthly Review
The slide at time 1m36 cuts to the next one too early so that the end of the audio narration is cut off.
In Neck Mobility B, at 6:54 it sounds like the narrator says “take a deep breath in as you exhale. And drop your shoulders…” rather than what he probably meant, “take a deep breath in. As you exhale, drop…”
If I could take a deep breath in as I exhale, I’d probably be a more efficient cyclist, but it’s not as easy as it sounds…
Hello, at the end of recent FF, the heart rate ranges were remarkably precise…!
On closing at reopening the Athlete profile a more sensible range was visible without being calculated to near Pi levels of precision…
Screenshot 2023-09-02 at 13.10.52|690x350
Just noticed an error in Tempo High Cadence: 4 x 3.
In the description area at the bottom it says there are 3 sets. From the name and the graphic it is 4.
Wrong image in the Workout of the Week.
Mental Training - 19. Planning For Every Event Scenario
At the 1m20s mark, the slide cuts off too early, while the audio hasn’t finished the final sentence.
In Dynamic Focus 8 there’s an exercise in which the audio description and text say “squat jump repeats” but the video is “scissor jumps”
Tagging @Rupert to look at this. It might be difficult to fix as they probably need a voiceover plus fixing the text.
In “Fight Club” (this is the new edition, I believe) there is a double space between the words “throw” and “punches” at 24:39 into the ride.
In fact, this is a great
time to throw punches…
Screenshot:
2023-09-23 11_01_53-Greenshot
@Rupert Tagging Coach Rupert to take a look.
Thanks for flagging, Fight Club has been addressed.
For some of the others keep listing them here, they are not as straight forward so I cannot do the instantly but great to have them on the list nonetheless so we can fix long term.
Sufferlandrian National Day and I just spotted an error in the description of The Kitchen Sink. part eight is not from TGTTOS but rather The Way Out
Thanks this has been updated!
Starters NoVid workout - good workout to fit in the gap between work and beer (ahem)
  1. just after the warm up peaks, the on screen text says it’s less than a minute until the first rep - it’s about 2 minutes
  2. can we have 10-20 seconds of 50/60rpm cadence just before each rep to mimic a real world start (like the UCI BMX video does)
  3. it’s a stem chewing workout, can you add some audio cues for the cadence/power changes in each rep
  4. warm down cadence in last 3 minutes shows as 0, no on screen text to choose your own so this may be an error
Tagging @Rupert for their attention
Recharger:
Just over 2 minutes in
Should be seems.
And just at the end of the second pyramid Cav?:
Certainly in UK English should be run, not ran
Thanks for flagging updates made
In the Chrysalis workout the link for “Instructions on how to use Chrysalis without a treadmill…” is broken. (points to: https://support.thesufferfest.com/hc/en-us/articles/360001328515-Running-and-Triathlon-Workouts which is a 404)
Mike Cotty had a slight slip of the tongue in the (wonderful) French Pyrenees: Cirque de Gavarnie On Location workout. About 14 minutes in, he mentions that Napoleon III visited a particular location “in the 1900s.” Not likely, since Napoleon III died in 1873. Pretty sure that he meant to say 19th century.
I’ve just ridden “Georgia On My Bike” - probably my fave Inspiration ride.
In the Calendar, once completed, the workout is listed as “Georgia On My Mind”.
