My new toy for this season is an ELEMNT Roam (v1) computer to replace my very basic Garmin Edge 130 whose battery was starting to fade.
After trying a few SYSTM workouts outdoors, I’m wondering how others manage the inevitable conflicts between the power called for in an interval and the terrain.
The loop that I use for workouts is over very gently rolling terrain. It’s difficult to stay anywhere close to the 50% or less of FTP that’s called for during a recovery interval if the grade is even slightly up; one very easily gets into tempo or even above threshold. So, just coast for a bit to average things out? Or just do the best that you can with gear changes, even if that means a lot more shifting from big to small ring than I would do normally?
The opposite also occurs, hitting a slight downhill just as an MAP or AC interval is called for, although this is a more easily managed with cadence and a higher gear.
Prior to getting the Roam, I would just plan a workout around the terrain, i.e., do MAP, AC, or NM efforts where I know there is a slight, steady upgrade and recovery where it turns slightly down.
I’m curious to know what other’s experience is with this.
